WW2 Weekend - 8th June 2019
Re: WW2 Weekend - 8th June 2019
That’s why you have the ‘Mancy Lad’ as a sub commanderWorld2dave wrote: ↑Thu Jun 06, 2019 7:39 pm Err, I think I'll take the right flank Bob. Unless you could drop a few bits of cover into the 'field of certain death' on the left?
Nice looking table Keremy
Keremy? That’s a new one for predictive text.
That big open field of death won’t be a British advance problem - at least not initially.
It’ll be a German withdrawal one.
The Aryan Master Race will be forward-deployed... otherwise, what’s stopping them blowing the bridge turn one?
Also, note the instruction: “you may not sacrifice your troops.”
Nod to the fact that they will initially be in a position to be sacrificed!
Ah..... if only it were so simple young Master Landings.... The demolitions need to be set first. The way this works is, every time you activate them, I roll a dice in secret, and when those dice reach a pre-determined tally, you will be informed that the bridge is then ready to blow. Of course, we then dice to see if the bridge does blow successfully. Charges may have to be reset...
SUICIDE VEST. FOR THE FINAL VICTORY!
Isn't that Norman Bin Landings?
That would also work
Norman Von Landinghausen!
