What's on your workbench?
Tell us more of your 6mm interwar?
Personal projects today - I did a 28mm torso-&-legs, with a view to using up Gripping Beast spare heads ‘n arms.
Chain mail is a sod to get right. I’ll need practice.
Did another face between stages to keep busy. Maybe quarter of the size of yesterday’s, but a way to go before I’m doing 28’s.
This week I have been painting 15mm Wellingtonic Bavarians (mixture of Battle Honours and AB Figures) and a load of scenery that's been lying around half-finished for the last year - a dozen big trees, 50-odd medium-sized trees, about 18 feet of hedgerow and made a start on 50-odd small trees.
That brush-cleaning water looks a bit used.
Bavarians, though - nice, mate. Very, very nice.
BaronVonWreckedoften wrote: Mon Jul 15, 2019 3:34 pm That brush-cleaning water looks a bit used..
I thought it was a case of "when you've gotta go...." !
I'm a tree junky but those ones look particularly great :)
I to like the trees. And the Bavarians.
Ta! I accidentally found the perfect glue for sticking foliage to Woodland Scenics tree-armatures. I'd previously followed someone's advice and tried PVA, but that was absolutely hopeless. I was going to use Bostik or UHU but had run out, so went up to the local farmer's supply shop to see what they had. This turned out to be Bison Contact Adhesive, which I'd never heard of it, but decided to give it a go and it turned out to be fantastic! It's got about the same consistency as Bostik, but far less stringy, not as smelly and is incredibly tacky - the foliage just sticks immediately to it and firmly stays put. It's a bugger to get off your fingers, but worth it, as the trees were done in record time. Just another 200 or so left to do... :(
I also tried two methods of foliating the trees - one is a sort of miniature camo-net that you rip into pieces and then drape over the (glue-covered) branches. The other type is 'foliage clusters', which is compressed lumps of ground-sponge flock that you then tease apart and stick onto the branches. Both look good - I think I prefer the look of the clusters, but the netting is marginally quicker to do. I think I'll continue with a mix of both types.
Yeah, I've tried PVA and lumps of foliage came off.
MarshalNey wrote: Mon Jul 15, 2019 6:03 pm Yeah, I've tried PVA and lumps of foliage came off.
Yeah, it took half an hour to do one tree and even after it had dried lumps kept falling off. Bison contact glue is the way forward! :moredrink:
