Muster Miniatures?
For traders and such to entice us to open our wallets
Re: Muster Miniatures?
Next long weekend, or even during an idle coffee break and it's good bye Lalo
Norman D. Landings wrote: Tue Jun 18, 2019 8:25 pm Dammit, I want to be a suave international smuggler of something or other!
Not sausage, though. I can see where you’re going with that nonsense.
Well you could smuggle vacuums now they are made abroad....
I can see a lot of budget airlines having accidents because the crews don't factor Norm's "lead mules" into the all up weight.
Here's a tip, if you load the aircraft from the back and the nosewheel starts to lift off the tarmac de-plane the passengers who can't seem to sit comfortably.
Zenbadger
Post by Zenbadger »
There are going to be a lot fewer "fixed bayonet charging" poses, that's for sure.
Soft plastic sounds like a better bet.
grizzlymc wrote: Wed Jun 19, 2019 12:58 pm Soft plastic sounds like a better bet.
Soft plastic cavity fillers.......
That's it, Norman can become a Cavity filled mule. He could masquerade as a vacuum salesman.
Our Man in Havanna!
Our Man in Havacuum?
If you're going to use a vacuum cleaner to fill cavities it should be set to "Blow". That's pretty much what the guys who did our wall used.
