Heroics and Ros seem to be shut. Anybody know who else makes 1/300 WW1 aircraft?
I know Irregular do, what’s the quality like?
WW1 aircraft
- Slugbalancer
- First Base
Re: WW1 aircraft
H&R aren't shut but they are only doing some of there ranges at the moment.
Irregular do seem to be the only other UK 6mm WWI aircraft maker. The pictures on their site aren't encouraging. Check them out
http://www.irregularminiatures.co.uk/6m ... 6mmWW1.htm
The other ranges will be added as they gear up.Ranges now available 25/07/20
The 1/600th Coastal Forces
The 1/300th Naval range and aircraft and useful bits for naval wargaming.
The 1/300th WW2 aircraft range.
The 1/300th WW2 Figure range.
