[Wanted] Various 15 mm Essex Medievals
vexillia
Fallen Woman
Post by vexillia »
I'm looking for any of the following that may have been left over from a larger project:
MER36 Early Renaissance: Dismounted Knights / Men At Arms 1400- 1500AD
EMED30 Russian 1300-1500: Spearmen with Kite Shield
EMED30a Russian 1300-1500: Spearmen with Round Shield
EMED31 Russian 1300-1500: Archers
I'm looking for one pack of each (8 figures). Unpainted preferred but will accept painted versions at a pinch.
Martin Stephenson :: Work | Blog | Auctions
Re: [Wanted] Various 15 mm Essex Medievals
Even in Medieval times, duplicating the vast empty wastelands of Essex in 15mm is nearly impossible.
grizzlymc wrote: Thu Jan 21, 2021 9:49 pm Even in Medieval times, duplicating the vast empty wastelands of Essex in 15mm is nearly impossible.
It's true. Essex is vast.
I can usually find this sort of figure stashed in the shed but I don't remember seeing any like this. I do have other medieval types though. Should I check, or are you wanting these castings specifically?
vexillia
Fallen Woman
Post by vexillia »
Essex Boy wrote: Fri Jan 22, 2021 10:24 am Should I check, or are you wanting these castings specifically?
Yes and no! :-) I do want these to match others but have look in your lead shed and send me some photos as I'm also after a few late medieval command figures for my levy archers.
After last time it is only a few. ;-)
They might be buried under the shredded lettuce.
