Ayton, Friday 29th April - Sunday 1st May 2022.
Re: Ayton, Friday 29th April - Sunday 1st May 2022.
That's cool, just good to know early.
Will Major, Goat still be running his 18th Century D&D game as a sideline?
Probably not but I'll put it on hold and do it on a later occasion I think
Good, I was looking forward to that one.
Sounds like a plan, funnily enough I quite fancy painting some Seven Years War figs, haven't done any for quite a while, I'm a bit short of Heavies.goat major wrote: ↑Wed Dec 01, 2021 10:37 am Sorry you couldn't make it John. We'll have to do a Ryedale bash again soon (maybe even invite some other North Yorkshire interlopers).
Yes next year will be 28mm (or probably 25 - 30mm) so you should be able to add to the lead mountain on the table !
Just had a quick measure up and my foot units are near as makes no difference 9 inch frontage 30 figures in 2 ranks. My cavalry are squadrons of 9 figures in single rank on roughly 7 inch frontage, acceptable or do I need to tweak anything ?Essex Boy wrote: ↑Tue Nov 30, 2021 7:42 pmAim for a frontage of about seven or eight inches for close order foot. A little bigger or a little smaller makes no difference. Include enough figures to make it look like it's a close order unit - so two ranks would be best.FreddBloggs wrote: ↑Tue Nov 30, 2021 3:01 pm Do these rules do away with you having to draw cards or roll dice EB, you know, to give you a chance!
As an aside, should I be able to make it, what size are the units for this game, so even if I do not have an army I can have painted some tricorns ready?
Cavalry have roughly the same frontage as foot (regardless of type). Make them look close order if they're dragoons or heavies - lighter cavalry can be opened out a bit if you want, but that's not important. Whether you have two ranks of troopers in a unit or just one is up to you.
One gun model is a battery (at the moment it is at least).
Ideally, you would have three units and a battery brigaded together with a mounted brigade commander, but I'm sure you'll be able to borrow extra troops to make up a brigade.
Hope that helps.
Nah, should be fine. Most people have roughly 15-20mm frontage per figure and units sizes from 24 - 36 men, so yours should fit in nicely.
No need to rush out and re-base.....unless you're EB
For gods sake, don’t ask EB a question like that. He’ll have you rebasing your entire army to his mad standards!
octagons......
- Buff Redux
So close order could be 30-48 figures, A brigade seems doable.
