Pendraken's 2025 Releases and News!
For traders and such to entice us to open our wallets
Leon Pendraken
Fallen Woman
Post by Leon Pendraken »
We'll start this with a really useful release with a load of handy shapes for making roads and rivers!  These are available in a huge variety of shapes and sizes, with straights, curves, junctions and more in widths from 20mm up to 75mm.
Despite these being simple MDF shapes, the possibilities are almost endless.  A quick coat of grey and some white lines gives you a road, a coat of brown and some static grass gives a country lane, and painting them blue/green/brown makes for an easy river (depending on your view of water colours...)  You could even paint both sides and flip them over depending on what you need for each game.
And the best bit is the value for money.  These are priced very competitively so you could build a full 6ft river or road for less than £5 if you wanted!
And to show what can be done with these, our friend Dave Docherty took some of the test pieces and used them for a 15mm winter table he's been building.  We've included some images below but you can see the full process on his blog here: https://onemanhisbrushes.blogspot.com/2 ... table.html
Roads and Rivers - https://www.pendraken.co.uk/roads-rivers
Roads
ROA-ST-20    Straight section, 20x150mm    £0.30
ROA-ST-25    Straight section, 25x200mm    £0.50
ROA-ST-30    Straight section, 30x250mm    £0.75
ROA-ST-40    Straight section, 40x300mm    £1.25
ROA-ST-50    Straight section, 50x300mm    £1.75
ROA-ST-75    Straight section, 75x300mm    £2.50
ROA-45-20    45° curve, 20mm width    £0.30
ROA-45-25    45° curve, 25mm width    £0.50
ROA-45-30    45° curve, 30mm width    £0.75
ROA-45-40    45° curve, 40mm width    £1.25
ROA-45-50    45° curve, 50mm width    £1.75
ROA-45-75    45° curve, 75mm width    £2.50
ROA-90-20    90° corner, 20mm width    £0.30
ROA-90-25    90° corner, 25mm width    £0.50
ROA-90-30    90° corner, 30mm width    £0.75
ROA-90-40    90° corner, 40mm width    £1.25
ROA-90-50    90° corner, 50mm width    £1.75
ROA-90-75    90° corner, 75mm width    £2.50
ROA-TJ-20    T-junction, 20x150mm    £0.30
ROA-TJ-25    T-junction, 25x200mm    £0.50
ROA-TJ-30    T-junction, 30x250mm    £0.75
ROA-TJ-40    T-junction, 40x300mm    £1.25
ROA-TJ-50    T-junction, 50x300mm    £1.75
ROA-TJ-75    T-junction, 75x300mm    £2.50
ROA-XR-20    Crossroad, 20x150mm    £0.30
ROA-XR-25    Crossroad, 25x200mm    £0.50
ROA-XR-30    Crossroad, 30x250mm    £0.75
ROA-XR-40    Crossroad, 40x300mm    £1.25
ROA-XR-50    Crossroad, 50x300mm    £1.75
ROA-XR-75    Crossroad, 75x300mm    £2.50
ROA-YJ-20    Y-junction, 20x150mm    £0.30
ROA-YJ-25    Y-junction, 25x200mm    £0.50
ROA-YJ-30    Y-junction, 30x250mm    £0.75
ROA-YJ-40    Y-junction, 40x300mm    £1.25
ROA-YJ-50    Y-junction, 50x300mm    £1.75
ROA-YJ-75    Y-junction, 75x300mm    £2.50
Rivers
RIV-ST-20    Straight section, 20x150mm    £0.30
RIV-ST-25    Straight section, 25x200mm    £0.50
RIV-ST-30    Straight section, 30x250mm    £0.75
RIV-ST-40    Straight section, 40x300mm    £1.25
RIV-ST-50    Straight section, 50x300mm    £1.75
RIV-ST-75    Straight section, 75x300mm    £2.50
RIV-45-20    45° curve, 20mm width    £0.30
RIV-45-25    45° curve, 25mm width    £0.50
RIV-45-30    45° curve, 30mm width    £0.75
RIV-45-40    45° curve, 40mm width    £1.25
RIV-45-50    45° curve, 50mm width    £1.75
RIV-45-75    45° curve, 75mm width    £2.50
RIV-90-20    90° corner, 20mm width    £0.30
RIV-90-25    90° corner, 25mm width    £0.50
RIV-90-30    90° corner, 30mm width    £0.75
RIV-90-40    90° corner, 40mm width    £1.25
RIV-90-50    90° corner, 50mm width    £1.75
RIV-90-75    90° corner, 75mm width    £2.50
RIV-YJ-20    Y-junction, 20x150mm    £0.30
RIV-YJ-25    Y-junction, 25x200mm    £0.50
RIV-YJ-30    Y-junction, 30x250mm    £0.75
RIV-YJ-40    Y-junction, 40x300mm    £1.25
RIV-YJ-50    Y-junction, 50x300mm    £1.75
RIV-YJ-75    Y-junction, 75x300mm    £2.50
RIV-WD-20    Widening section, 20-25x150mm    £0.30
RIV-WD-25    Widening section, 25-30x200mm    £0.50
RIV-WD-30    Widening section, 30-40x250mm    £0.75
RIV-WD-40    Widening section, 40-50x300mm    £1.25
RIV-WD-50    Widening section, 50-75x300mm    £1.75
RIV-WD-75    Widening section, 75-100x300mm    £2.50
RIV-SP-20    Straight with pool, 20-40x150mm    £0.30
RIV-SP-25    Straight with pool, 25-50x200mm    £0.50
RIV-SP-30    Straight with pool, 30-60x250mm    £0.75
RIV-SP-40    Straight with pool, 40-80x300mm    £1.25
RIV-SP-50    Straight with pool, 50-100x300mm    £1.75
RIV-SP-75    Straight with pool, 75-150x300mm    £2.50
http://www.pendraken.co.uk - Home to over 10,000 products for wargaming, including 5000 items for 10mm, MDF bases, buildings, decals, Litko, Raiden aircraft, Red Vectors MDF products, Vallejo, Tiny Tin Troops flags and much more!
Leon Pendraken
Fallen Woman
Re: Pendraken's 2025 Releases and News!
One for the bigger scales next, with a mining set now available comprising of brick engine house and winding gear, for both 20mm and 28mm scales.
These setups would have been found across Britain in the 19th and early 20th centuries, with the house containing a steam engine for either hoisting the mined materials to the surface, or pumping water out from the mine below.
They're probably not the most in-demand wargaming item but they'll make a nice addition to any 'What if?' type games like A Very British Civil War.
Red Vectors MDF - https://www.pendraken.co.uk/red-vectors-mdf
RED-20BR-01    20mm Mine engine house and winding gear    £14.00
RED-28BR-01    28mm Mine engine house and winding gear    £22.00
Leon Pendraken
Fallen Woman
We've got a new addition to the Battlescale 6mm ranges this week, with a Harbour Masters House now available.  Steve made this model as a tribute to a friend who sadly passed away:
"Well, I was planning for my first new piece of the year to be in 10mm. However, since hearing the really sad news about the passing of my friend Ian, I felt I had to create something as a small tribute to a lovely man.
Ian was a ‘salty sea dog’ in a previous life and spent many years in the Royal Navy. His affinity with the sea stayed with him it seems throughout his life. He often spoke of his time at sea and made several videos regarding the ever eroding coastline in his part of the country.
As a wargamer, like many of us, he was somewhat of a butterfly, skipping from one era, one scale, to the other. His first passion was ACW in 6mm and he always seemed to find his way back to it in one form or another. Having thought about all this I decided to make a harbour masters house in 6mm."
Battlescale - https://www.pendraken.co.uk/battlescale-6mm-buildings
BAT-6B054    Harbour Masters House    £4.00
(Supplied unpainted)
And a quick pic of course!
Looks like a worthy memorial, Leon. Well done.
Those road/river pieces look the business. How thick is the mdf?
Leon Pendraken
Fallen Woman
BaronVonWreckedoften wrote: Tue Feb 25, 2025 10:52 am Looks like a worthy memorial, Leon. Well done.
Steve's done a great job on it.
Peeler wrote: Tue Feb 25, 2025 7:49 pm Those road/river pieces look the business. How thick is the mdf?
All 2mm MDF for those.
Thanks
Leon Pendraken
Fallen Woman
We've got another 28mm MDF release for you next with a set of 3 buildings from the Falklands Islands.  The main building is Top Malo House, the site of a skirmish between British Marines and Argentine Commandos in May 1982.  The other two are based on other small buildings in the same area.
Despite the above, they're still fairly generic and should be OK for multiple other regions of the world too.
RED-28FLK-01    28mm Falklands House Set    £12.00
Leon Pendraken
Fallen Woman
Vallejo have been updating some of their Model Color paints recently and we've just got our stocks of the new colours. These are all priced at £2.75 and they also qualify for our '5 for £13' offer on all of the Model Color and Game Color paints.
We've also decided to stop stocking the Panzer Aces paints, as the most popular colours in this range have now been duplicated in the new Model Colors. We also don't have space on the display rack to take them to shows, so it's better to sell off the remaining stock and focus on the main ranges.
So if you're looking for some bargain paints, the Panzer Aces colours have all been reduced down to £2 per pot in our Clearance section: https://www.pendraken.co.uk/vallejo There's also a few discontinued Model Colors in there too.
New Colours: - https://www.pendraken.co.uk/vallejo-pai ... r-acrylics
VAL740 Camo Middle Brown
VAL741 Camo Black Green
VAL745 Dark Rose
VAL746 Chestnut Brown
VAL747 Faded Red
VAL748 Light Pink
VAL749 Dark Purple
VAL750 Light Violet
VAL751 Black Violet
VAL752 Infantry Blue
VAL753 Light Blue Green
VAL754 Continental Blue
VAL755 Light Emerald
VAL756 Splinter Green
VAL757 Pacific Green
VAL758 Bright Green
VAL759 German Tank Crew
VAL760 Light Mud
VAL761 Old Wood
VAL762 Grey Brown
VAL763 Canvas
VAL764 Military Yellow
VAL765 Desert Tan
VAL766 Cream White
VAL767 Desert Brown
VAL768 BC Dark Brown
VAL769 Mustard Brown
VAL770 New Wood
VAL771 Dark Rust
VAL772 Medium Grey Blue
VAL773 Violet Grey
VAL774 Lavender Grey
Leon Pendraken
Fallen Woman
We've got a big extension to our 10mm American Civil War range this weekend, with nearly 20 new codes added to our already comprehensive selection.  We've got a load of infantry in frock coats, six new cavalry types, as well as some handy Western theatre troops too.
10mm ACW - https://www.pendraken.co.uk/10mm-19th-c ... -civil-war
ACW70    Infantry in frock coat and kepi, marching
ACW71    Infantry in frock coat and kepi, advancing
ACW72    Infantry in frock coat and kepi, firing line
ACW73    Infantry command in frock coat and kepi (15)
ACW74    Infantry in frock coat and hat, marching
ACW75    Infantry in frock coat and hat, advancing
ACW76    Infantry in frock coat and hat, firing line
ACW77    Infantry command in frock coat and hat (15)
ACW78    Infantry in battle shirts
ACW79    Labourers with rifle stack
ACW80    Zouaves in shirts
ACW81    Dismounted infantry
ACW82    Mounted Infantry
ACW83    1st Virginia cavalry
ACW84    Mounted guerrillas
ACW85    Jayhawks/Redlegs
ACW86    Cherokee Rifles
ACW87    Western theatre infantry, advancing
ACW88    Western theatre infantry, firing line
Infantry in frock coat / kepi, marching:
Infantry in frock coat / hat, firing line:
Infantry in battle shirts:
Labourers:
1st Virginia cavalry:
Jayhawks/Redlegs:
Western theatre infantry, advancing:
