SYW artillery
SYW artillery
I finally managed to secure some SYW Austrian gunners - Revell - all of 7 figures at some cost but they get me out of trouble.
They came with 2 of the guns from the set; 3 pounders. They're perfectly acceptable guns but I need field artillery, not regimental guns.
Any ideas where you can buy (probably metal) SYW artillery pieces at 20mm -1/72 scale?
Ilkley Old School
Re: SYW artillery
Post by Ilkley Old School »
Lancer miniatures have some 20mm SYW artillery.
Re: SYW artillery
Hinchliffe?
Or failing them, I could buck my ideas up and send you that box of Revell I have gathering dust.....
:fp:
Re: SYW artillery
What? Old John hasn't sold you SYW artillery? I'm shocked.
Re: SYW artillery
I checked out the Lancer site. The figures look kind of small....are the guns compatible with, say, the Revell gunners?
Re: SYW artillery
I have a brigade of Lancer 20mm LoA figures.
I don't know about the equipment, but the foot figures measure up between Irregular and Les Higgins in height (much chunkier than both though). I suspect Revell gunners will be far too big.
Are you after generic guns, or something more specific?
Ilkley Old School
Re: SYW artillery
Perhaps older 25mm artillery would be better. Hinchcliffe or Warriorc25mm French Napoleonic pieces may work.
Re: SYW artillery
I think it may be safer to just buy a set of the Zvevda GNW Swedish artillery. Probably a little old fashioned but at least the right size.
Re: SYW artillery
If you can get a set in Australialand then that must be the best bet. Hinchcliffe guns are excellent, and Warrior are quite good, and cheap.
Re: SYW artillery
Looking at the few photos available on the net http://randomncreative.blogspot.com/201 ... llery.html they should work just fine. Both the Russian & Prussian SYW or GNW sets available would work too. After all, captured guns were not infrequently put into service against their former owners!
