Macedonian pikes
Macedonian pikes
A very pleasant chap* has sold me a pile of Newline (ie 20mm) Macedonian phalangites.
When they arrive, he's warned me, they are sans pike. A pike-less pikeman seems to defeat the purpose so I'll need to acquire some pointy sticks of a suitable length.
Firstly size: I gather they were 4-6 metres (quite a discrepancy). This translates to over twice the length of the figure if you go with the minimum. I think, given the exigencies of storage, about 50mm should look about right?
Does anyone have a source for such items? I'm thinking the actual scale of the figures should not matter when buying spears or pikes etc, as long as you get a required length.
* you may know him. He goes by the alias 'Iain of Essex'. Well known (miniature) arms dealer.
Re: Macedonian pikes
I use the 'soft' iron florists wire available for a few bucks at your friendly local craft superstore. (eg https://www.ebay.com.au/itm/80Pcs-White ... SwvDpbD7iR ) I use it for my 15mm ECW pike - which are around 5m long IRL (5cm for 15mm)). Cut to approximate length with wire cutters - if you do it at an angle they end up with a sharp tip. a bit of careful painting - wooden shaft, gunmetal or black for the tip and the 'cheeks' & they're more than serviceable IMHO. They will bend with pressure but they're less delicate than the whitemetal equivalents. I think it's known as 'stem wire'.
If you're worried about the sharpness, then an alternative is to cut the plastic bristles from a broom, preferably not the best one!. I use bristles for aerials on my vehicles, as it's possible to get the 'bend that is often seen on a long aerial.
Another alternative is brass rod, cut it bundled with a hacksaw and bang the end with a hammer. The sharpness discourages beer bellies bending over the table without a care.
Surely he sold you them without pike as they will be based and deployed in their skirmishing role?
Damn it. Andy beat me to it
What's this....
That was me ignoring you both.
Donald - people have spoken of using plastic bristles from a brush.
I use piano wire, but it needs shaping with a grinder.
What gauge is piano wire or does it come in different sizes ?
Essex Boy wrote: Sun Dec 06, 2020 2:07 pm I use piano wire, but it needs shaping with a grinder.
Do you have to swipe left or right?
goat major wrote: Sun Dec 06, 2020 2:10 pm What gauge is piano wire or does it come in different sizes ?
It comes in several sizes. Unfortunately, I have a bundle of it and pick out the gauge that looks right at the time. I believe 1mm suits for 28/30mm figures, so perhaps 0.75mm for 20mm pikes. It's a beast, but there's no chance of spaghetti weapons.
