Table
Table
Due to storage issues I’m having a cut down of stuff and a rejig.
Anyone had any experience with these?
https://www.gamemat.eu/our-products/fol ... g-area/en/
Or anything similar? I need really a foldaway thing I can put mats on.
Re: Table
I assume you meant the table:
https://www.gamemat.eu/our-products/fol ... -g-mat/en/
Only a brief experience, it seemed ok and quite neat when folded away. I wouldn’t rest anything heavier than a small child on them.
The trestles I use (with an MDF board) are strong enough to take a small adult and are height adjustable but not as neat folded away:
https://www.uktoolcentre.co.uk/products ... gLOhfD_BwE
Re: Table
levied troop wrote: Wed Dec 27, 2017 2:29 pm I wouldn’t rest anything heavier than a small child on them.
That precludes a visit from the Gateway cavalry then. Though admittedly the table wouldn't be under any stress for long...
Re: Table
Frankly I wouldn't touch that table with the proverbial barge pole. It looks very expensive and might give way if leant on too heavily if the blurb is to be believed.
Wouldn't a standard drop leaf dining table work or some good quality pasting type tables. basement Mark bought some rather nice plastic folding tables for his shop that weren't pricey but he can't remember where he got them from.
Some MDF, Hinges and basic woodworking skills could get you a folding setup that would take more weight.
Re: Table
Costco still do some very strong folding tables at 4’x2’ and 2’x2’, if you are a member of course. Before GHQ was up and running we used these. You can stand on them, so no worries with terrain & masses of cavalry. The tops are some type of rigid plastic and the folding legs metal. We kept one for pasting wallpaper and Sue uses it when crafting.
Re: Table
Penda wrote: Wed Dec 27, 2017 4:41 pm The tops are some type of rigid plastic and the folding legs metal. We kept one for pasting wallpaper and Sue uses it when crafting.
Those sound like the excellent ones Basement Mark had, his came with plastic fabric cases to store them in too.
Re: Table
You should stop doing that, you'll get into trouble.
Re: Table
Count Belisarius wrote: Wed Dec 27, 2017 2:42 pm
The truth hurts.
Re: Table
Thanks for all the posts.
Is weight really an issue? What heavy things are you lot flopping on the table?
Re: Table
Body parts.
Generally it’s elbows or someone leaning on it while standing over the table.
