Is there a good yellow hobby paint? I'm using 2 different Vallejo ones but the result is slow to achieve anything acceptable.
I get that it's opaque but the number of coats required is a bit excessive.
Just live with it?
Yellow
Re: Yellow
I’ve never got on with vallejo yellows. My best results come from one of the following depending on mood
Foundry Ochre triad. Ignore the name, it’s yellow and gives great coverage as a triad
Citadel averland sunset is an really good high pigment base coat. Excellent coverage , you can highlight it up for brighter yellows
Citadel Iyanden yellow contrast paint over a white (or near white) undercoat gives a very pleasing result
Re: Yellow
Lots of thin coats of Vallejo yellow work. I speed it up by using a hair dryer on coats
A yellow brown base works well for them
Re: Yellow
This^^goat major wrote: ↑Sat Jul 24, 2021 2:48 pm Foundry Ochre triad. Ignore the name, it’s yellow and gives great coverage as a triad
Although I am filled with fear now that I am coming to the end of my stash of these and I have heard that the quality of Foundry Paint has slumped somewhat recently
Re: Yellow
I re stocked the ochre triad recently and it seems fine
Re: Yellow
Look no further than the Foundry Ochre shade and light, great coverage and solid colour. I largely ignore three layers now on wargames figures as you may have noticed. No time for angst about it all.
Re: Yellow
Vallejo yellows work well for me
I mix VJ Desert Yellow (or Goldbrown)and Flat Yellow for a base coat and then either use flat yellow alone for second coat or some of the other yellows like deep yellow or light yellow, sometimes add pale sand depending and what tone I want
That's also over a black undercoat
- Zenbadger
Re: Yellow
Averland Sunset is my goto yellow base.
Re: Yellow
Humbrol yellow, if putting it on a dark surface, put down some matt white first.
