Spear girth.
Spear girth.
Hi all, looking for some spears. Ladt lot I got are very thin and don't quite look right on the figures. Was wondering if anyone had any recommends on decent spears in 28mm for models what need them.
Re: Spear girth.
There I was thinking this was about satisfying Gaynor.
- Zenbadger
Re: Spear girth.
I tend to use big paper clips from Rymans, they are about twice as thick as the wire spears from Gripping Beast etc. but take a bit of shaping. I hammer them straight, flatten one end and then shape it to a point with a pair of side cutters and a needle file.
Re: Spear girth.
Believe it or not this is the third time in two days that I've written this. Try plastic bristles from a yard broom. Flatten one end and cut yer diamond shape pike head and it's done. A friend has used them for years for his Ancient phalangites and ECW pikemen. They are are both strong and flexible -a bit like Gaynor I suppose.
MickS
Re: Spear girth.
Do you do that technique for your 6mm subs ? Or are the bristles too thick ?
Re: Spear girth.
Paint brush bristles - they make good radio aerials too.
Re: Spear girth.
i tried that but i still can't get a good signal for Radio 5
Re: Spear girth.
A spear shaft in scale for 28mm should only be about 0.8-0.9mm at most. But we are not dealing with a representation of life and thin spears can look wrong against chunky figures. I think my spears come from Perrys or foundry. I bought a lifetime supply years ago and haven't managed to get similar ones since!
