Magnet and Steel
Magnet and Steel
Inspired by everyone's storage methods I was wondering where to get the best magnet sheets and steel paper from?
I want to line the really useful boxes, roughly the A4 sized ones.
Re: Magnet and Steel
I use this mob, always been very good, do a lot of shows
http://www.magneticdisplays.co.uk
This site is also useful:
https://www.first4magnets.com
Never used the second one, but I can also vouch for the first retailer - good stuff, fits A4 well, and fairly easy to apply (if you aren't a double-cack-handed so-and-so, like me). They'll be at Partizan if you want someone to pick something up for you.
check the magnetic strength though - it can be a lot weaker than you expect especially with 28mm metal figs.
I use the first named, not sure on the magnetic pull though.
I hear you were caught trying to pull one off on Sunday night
It was alleged, but I deny it unanimously. I was merely watering the plants.
I use steel paper stuck to the bottom of my bases, and washers. The self adhesive paper is I think from one of the above suppliers. I bought a load years ago! I then wait until the pound shops have A4 magnetic print paper at (unsurprisingly) a quid for two sheets. I just PVA that to the bottom of all my boxes. They always survive the trip to Ayton but I'm not sure they'd survive the Norm Staircase Test...
I do it that way round as I read somewhere ages ago that magnetic paper can lose it's magnetism over time and it's easier to line a new box than re-do all the bases! I've no idea if that's true or not but I'm not changing now!
Timmo
Post by Timmo »
Happy customer of the first named for many years now. I base on steel and line my boxes with the magnetic sheet. I've found that the heavy duty stuff can exert such a pull on steel bases, even of 40mm x 40mm that I now use the tape so there is less surface area. I was worried about breaking figures trying to prise them out of their boxes.
Count Belisarius wrote: Wed May 09, 2018 5:02 pm I do it that way round as I read somewhere ages ago that magnetic paper can lose it's magnetism over time and it's easier to line a new box than re-do all the bases! I've no idea if that's true or not but I'm not changing now!
Same here, there's no real cosmetic difference so it's better to ere on the side of caution.
