Advice on putty
Advice on putty
I quite fancy painting up a few trojan rampant units of these guys (the warrior on the right holding the spear). I havent seen anything similar in metal so It looks like a plastic conversion job. My question 1: relates to the "poncho" style bronze armour - would this be straighforward using that putty some of you use for conversions?
Question 2: any ideas on how to reproduce the horns?
I'm going for either Victrix Romans II or the Carthiginan citizan infantry or maybe both to complete the conversion.
https://www.victrixlimited.com/collecti ... nd-command
https://www.victrixlimited.com/collecti ... n-infantry
Zenbadger
Re: Advice on putty
Post by Zenbadger »
In greenstuff it would be pretty simple to roll some out thinly on some stretched clingfilm, use a blunt-ish knife to cut the shape then using the clingfilm apply the shape to the miniature. Press it into the body fairly firmly and then peel off the film before using a shaping tool or a knife to apply the detail of the lamellae. For the horns, which are really quite slim, I would cut a piece of soft wire to shape and then file it down to a taper at either end. Drill straight through the helmet, bend to shape and use some runny superglue to seal it in place. Not difficult but you wouldn't want to do more than a dozen of them.
Re: Advice on putty
Is greenstuff the name of the product?
Thanks for the advice. We'll see how the first figure turns out when I get the figures and materials.
Re: Advice on putty
Green Stuff or Kneadatite is another name. Look for the strips of blue and yellow chewing gum type stuff
Re: Advice on putty
I think Minibits now sell it and they do it in separate tubes. The strips where the yellow and blue are joined side by side can get a bit stiff over time where the two colours join.
Re: Advice on putty
Pretty sure you can buy it from the modelling section in Hobbycraft, too.
Re: Advice on putty
Count Belisarius wrote: Sat May 12, 2018 4:45 pm can get a bit stiff over time
Isn’t that what Gaynor said?
Re: Advice on putty
I think I can manage the greenstuff armour - not sure about the horns though!
Thanks for the info.
Re: Advice on putty
I prefer Milliput myself.
As badger says, you can get the job done simple enough but it will take a lot of time and patience, you might lose the will to live after three.
The horns as said, drill some florist wire in there. You could even pop some fat milliput sausages on the drilled in wires and then shave them down carefully with a knife when it’s set.
Re: Advice on putty
you can mix milliput and greenstuff to give a better handling putty.
Strangly that illustration is one I using for 6mm Achaens.
