What's a good way of painting shields separately?
Got cocktail sticks. Will stick em in blue tac but securing the shields well enough to paint might be tricky? How do you pointy stick people do it?
Re: What's a good way of painting shields separately?
Double sided sellotape on a piece of card. Or blobs of blue tac.
Little bit of wood glue works for when I want to do things like that
I don’t mind a glue gun splodge because it can peel off easily.
I just stick them to the figure and be done with it...
Why paint, do what I do, make your own shields on computer and print them off.
Attach to plastic, metal shields with wood / PVA glue.
All it takes is a bit of practice on the printing to get the correct sheild size.
It is best to undercoat / wood colour the shield before gluing, so you still have to do some painting.
Blue tack on a lollipop stick for holding them.
Zenbadger
Post by Zenbadger »
I can't take to paper or decals, a nicely painted shield is one of my favourite bits of painting. I blu-tack to an old pine doorknob, undercoat front and back, paint the back completely and then gloss varnish. Once this is completely dry I paint the front and gloss varnish again. Matt varnish the back and stick to the model, scraping the paint away for a metal to metal joint then matt varnish the front when it is on the figure.
Jeez Zen! Do you have sex upside down on a rocking horse, just because you can?
I actually thought it made a lot of sense.
It’s more or less what I do - Zen’s way that is, not inverted rocking horse sex (not since the caution).
