After some careful dry-fitting (Tabletop Workshop isn't easily available anymore and I don't want to screw up any of the pieces):
A quick check for height, looks about right for town walls:
My problem will be that the usual pack of walls has two but only one battlement/top walkway set as they are planned to be twice the height. I’ve only just realised that cuts down the length I can do
I also plan to build some breached sections to drop in as required, so a bit more fiddling about is needed to see how much length I can get
