I'll admit to buying very expensive Winsor & Newton Sable brushes. This is after decades of using fairly cheap brushes that never lasted long, lost points quickly & even when new, made painting difficult.
Clearly, I've bought bottles of brush cleaner, re-fresh the water container regularly & after painting, re-shape the point by inserting it (you know where). Anything to prolong the life & usefulness of these expensive tools.
However, I caught this in passing: "Never dry your brushes with cloth. Use tissue paper or paper towels".
No reason given: is this a thing? Any light you can shed on this?
Brushcare
Re: Brushcare
I’ve always used paper roller towel. Purely because it’s disposable
I suspect on cloth, the paint may dry hard and damage the bristles?
Re: Brushcare
I’ve seen comments that cloth rags if used need to be lint free. Possibly to stop loose fibres getting into your brush bristles ?
- Vintage Wargaming
Re: Brushcare
Rosemary & Co sable brushes can be a viable cheaper alternative to Winsor & Newton for some people
You can never have too much of something you never needed to start with
Some of my blogs:
http://vintagewargaming.blogspot.co.uk/
http://findthatfigure.blogspot.co.uk/
http://tankdevelopment.blogspot.co.uk/
http://georland.blogspot.co.uk/
Some of my blogs:
Re: Brushcare
I always use kitchen roll.
Re: Brushcare
I'm a Rosemary man too!
- Buff Orpington
Re: Brushcare
I'd keep something like that quiet, it's very close to lavender.
Re: Brushcare
OK, I'm in the market for new brushes. Looking at the Kolinsky stuff on Rosemary & Co, what types do people recommend? I normally paint 28mm and don't do huge amounts of detail..
Re: Brushcare
I’ve got a Windsor & Newton Series 7 that has probably painted about 500 or 600 figures over the last 3 years. Possibly more. And still as good as new. I clean it every few sessions with their brush cleaner, I let it soak overnight in the bottle.
Expensive yes, but if it lasts a few years, then it’s worth it.
Re: Brushcare
That's my thoughts. The break through was the new Eckersley's Art Supplies that opened down the road. In OZ, everything comes via expensive P&P so a readily available stock of W&N was a no-brainer.
