Frankenstein
Frankenstein
One of the benefits of using 1/72 plastics is the relative ease of modification.
I often exchange a head but rarely do much more. However, as my ACW 83rd Pennsylvania Regiment (uniformed as Chasseurs) needed a standard bearer, I did this:
Head from an Italeri figure, torso from an IMEX confederate infantryman, legs from a HaT zouave & the right arm from a Napoleonic Landwehr Prussian.
....time on my hands (though back to work on Monday! Yay!)
Re: Frankenstein
and the gluable soft plastics that Hat produce.
Re: Frankenstein
How are they gluable?
Re: Frankenstein
Special plastic and then a special two part glue.
http://www.plasticsoldierreview.com/Sho ... aspx?id=44
Re: Frankenstein
grizzlymc wrote: Fri May 08, 2020 8:28 am How are they gluable?
A pal of mine actually solders the bits together.
I'm not nearly so advanced or skilful. I pin the pieces (using cut up bits of staples) which, frankly, is enough. However, with belt AND suspenders thinking, I use super glue, as well. The type I use has the activator in a pen-like object.
https://www.bunnings.com.au/loctite-2g- ... e_p1210073
Any gaps have wood glue rubbed in & even the undercoat/primer adds to the union of the pieces.
I have never had any bits fall off (my figures, that is).
Re: Frankenstein
But around that time I made the move from plastics to metal.
The pinning method referred to by Donald is the best way to ensure a good bond.
Re: Frankenstein
Splendid work, Donald.
Way, way back when I last converted plastic figures, I made pins from very fine piano wire - thinner even than pins, and with a decent pair of pliers I could work the 'pin' well into the plastic for a permanent bond. PVA filled any gaps.
Re: Frankenstein
That is a top conversion!
