Little Big Man Decals
I'm thinking of taking advantage of the Newline sale & buying some Polybian Romans to replace the plastic HaT ones I have.
...and the issue of shield designs seems to suggest LBM decals.
You had any experience with these?
https://www.littlebigmenstudios.com/
The product looks great but the process of applying the transfers looks like a nightmare.
https://www.littlebigmenstudios.com/how ... transfers/
Re: Little Big Man Decals
They're pretty easy to work with with 28mm figures. I'm using some now on my Gauls. I've used them in the past for 15mm as well, which is a bit fiddly, but not too challenging. I'd recommend them if I were asked.
I’ve had a few problems with the process for Roman ‘bossed’ shields. I’m about to try again as it happens, there’s some useful suggestions here:
http://leadadventureforum.com/index.php ... c=125881.0
and the use of Microsol is recommended:
http://leadadventureforum.com/index.php ... c=125046.0
I have never used microsol, do you just splodge it on and it does its magic?
being self adhesive, does the microsol not affect the glue?
Used them a lot on many different armies. I’ve never needed microsol. Cut them out carefully, tissue with lots of water on and give it a good soaking. Then position and tamp down the edges with a craft knife or toothpick. Then carefully mop dry with a dry tissue. Then spray varnish.
LBMS rock :buddies:
They do indeed. They make my shitty painting look decent!
They can bring a crappy painted unit to life!
I did like those fellas a lot Ken
