Stripping
Re: Stripping
I normally recommend Dettol, but I've never used it on resin, only metals and plastics.
Re: Stripping
Whatever you use, slosh it on the underside to see if it reacts. Dettol is an alcohol so it probably won't damage the resin, but test anyway.
Re: Stripping
Try Isopropyl alcohol. It's fine on cured resin as it's what most folks use for cleaning uncured resin from their prints.
Re: Stripping
I suspect that the active ingredient in Dettol may not be very different from isopropyl alcohol.
Re: Stripping
Dettol is generally reported as fine for resin though I haven’t tried it myself. There are some reports that it makes finecast go slightly rubbery until they dry out. Not sure if that’s true but your tank won’t be finecast which is a bizarre material. For normal resin it seems to be ok.
Isoprop will strip nicely if you have only used acrylic paint. If you’ve got enamel or poly varnish you’ll need dettol to cut through it.
Re: Stripping
This is a much less interesting thread than promised by the title...
Re: Stripping
Frankly, given the title, its unheard of for us to remain "on topic" this long.......
Re: Stripping
Although the thought of my fellow wargamers sans raiment is not an appealing one.
Re: Stripping
Thanks chaps will try dettol.
