Problems with AK interactive ultra matte varnish
Atheling_2006
Hasty Harlot
Post by Atheling_2006 »
Hi,
I occasionally use AK interactive Ultra Matte Varnish on spots of any given miniature that I might have missed with Winsor and Newton Pro Matt Spray. I have not had any problems up to this point.
I haven't used the varnish in weeks; but now when I drop some out on my palette instead of the thin white vanish I'm not getting a light brown colour. I have not had the guts to use this on any miniatures.
I have the whole thing a severe shake and I'm still getting the same brown colour.
Has anyone else had this sort of a problem? Do I have a bad batch?
Cheers.
Re: Problems with AK interactive ultra matte varnish
Atheling_2006 wrote: Tue Aug 30, 2022 12:00 pm Hi,
Cheers.
Very occasionally, twice in forty years, i've had paint start to "rot" and start to smell off and discolour. Probably due to mould I think.
Atheling_2006
Hasty Harlot
Paul wrote: Tue Aug 30, 2022 1:03 pm
Cheers.
Thanks. It's definitely not mould..... I'm baffled
Wg Cdr Luddite
Post by Wg Cdr Luddite »
Do you have a ball bearing in the bottle ? Could be rust.
Wg Cdr Luddite
I know this because I have had rusty balls.
Atheling_2006
Hasty Harlot
Wg Cdr Luddite wrote: Tue Aug 30, 2022 3:42 pm Do you have a ball bearing in the bottle ? Could be rust.
I put one ion before shaking like mad today but not before. It's without doubt a bad batch.
I got in touch with AK earlier and they gave me a voucher but I still ended up paying nearly £20 to get more varnish! You have to spend a certain amount on their website to make an order and they obviously know this. :wall:
I usually get my AK paints from Great Escape Games (and usually at the shows).
Atheling_2006
Hasty Harlot
Jeremy wrote: Tue Aug 30, 2022 6:00 pm I usually get my AK paints from Great Escape Games (and usually at the shows).
Yeah, me too. I contacted the vendor I bought the varnish from Scale model Shop, who are usually excellent, from too but he was of very little help.
Basically the varnish was not fit for purpose and should have been replaced.
Jamanicus
Hasty Harlot
Post by Jamanicus »
Could it be something to do with the weather/heat we've recently had?? 🤷🏼‍♂️ Has there been any direct sunlight on the bottle?
On the ball bearing/rust thing...I got some 'stone' (I forget the actual material name) that are used for jewellery etc and they're great!!
Atheling_2006
Hasty Harlot
Jamanicus wrote: Tue Aug 30, 2022 7:29 pm Could it be something to do with the weather/heat we've recently had?? 🤷🏼‍♂️ Has there been any direct sunlight on the bottle?
nope. Kept in a very opaque box in a room that has no direct sunlight. If it were the heat we would surely be hearing from others who had the same problem. Also, I don't exactly live in a typically warm part of the UK.
Jamanicus wrote: Tue Aug 30, 2022 7:29 pm On the ball bearing/rust thing...I got some 'stone' (I forget the actual material name) that are used for jewellery etc and they're great!!
Sounds interesting. Do you have a link perchance?
