Priming metal bases
Priming metal bases
I always spray prime my steel bases with a proper metal primer. Do peeps do anything when using coins? Had a discussion about PVA not sticking that well to bare coins?
Re: Priming metal bases
I've never primed metal bases of any kind. In fact I've scraped the primer off the upper surface of those pre-primed metal bases because I don't like the idea of sticking anything onto a coat of primer.
I mix PVA with cheap filler for the first coat on my bases. That's never come off yet without some persuasion.
EB+1
What’s this spray bare metal primer you mention ?
Just Halfords primer. Nothing fancy.
Count Belisarius wrote: Sun Dec 29, 2019 12:10 pm Just Halfords primer. Nothing fancy.
+1
Is it the etch primer ?
Merry Christmas to you to. And a happy New Year.
goat major wrote: Sun Dec 29, 2019 12:21 pm Is it the etch primer ?
I just use the standard primers. Black, grey or white depending on what i'm using it for and how I feel on the day :)
Sometimes...…..sometimes....I even use the red primer :o
My shinys are stuck on steel washers. I'm just undercoating in humbrol enamel as normal. Am I doing it wrong?
I used to stick the figure on with contact adhesive and then the base would receive the same spray coat as the figure
